Chris & Doug
#1 Posted : Friday, February 6, 2009 4:31:30 PM(UTC)
Chris & Doug
I read that other people were having trouble where their microwave works but doesn't heat anything. Suggestion was made to replace the fuse, and we purchased one at Home Depot 20 amp 250V R30, but it still doesn't heat. The fuse we removed was E35 is there a difference. What could be wrong?
#2 Posted : Saturday, February 7, 2009 3:50:52 PM(UTC)
Can you be more specific on the problem? What it does and what it does not (besides the heating problem). Which fuse did you replace? There are two fuses in the microwave.
You have to have a simple multimeter in order to perform the troubleshooting.
Chris & Doug
#3 Posted : Monday, February 9, 2009 6:25:51 PM(UTC)
Chris & Doug
The microwave turns on the tray moves and everything appears to be working except there is no heat. It also does not defrost. I replaced the fuse behind the circuit board. My exact model # RMC275PDB1
#4 Posted : Monday, February 9, 2009 6:57:37 PM(UTC)
You have to remove the microwave from the oven cabinet to perform the troubleshooting. According to the wiring diagram the first failure suspect is the magnetron TCO (#31 on the diagram) which you have to test for continuity. Replace if it's open. Also you have to check for continuity both door switches (#51).
If there is nothing wrong then the magnetron has gone bad.
You can find the disassembly instructions in the Service manual.
Here are the break down diagrams for the Whirlpool oven and microwave combination Model RMC275PDB1
GE JE1640WB Microwave not heating, I think it is the magnetron (Microwave Repair)
by jmunjr 8/5/2020 3:55:45 PM(UTC)
GE Microwave Not Heating (Microwave Repair)
by JIMMIEM 2/3/2018 6:14:54 AM(UTC)
GE Advantium 120 Microwave not heating (Microwave Repair)
by Dnl221 4/3/2016 10:43:06 AM(UTC)
GE Microwave not heating up (Microwave Repair)
by jgilpin 11/15/2013 4:39:17 PM(UTC)
Whirlpool Microwave not heating (Microwave Repair)
by ddelay 10/15/2013 5:16:23 PM(UTC)
GE microwave not heating, sensor error (Microwave Repair)
by bk69 2/7/2013 2:24:15 PM(UTC)
by georgewade 1/29/2013 10:54:31 PM(UTC)
GE Profile Microwave Not Heating on Microwave or Convection Mode (Microwave Repair)
by stampede 11/8/2012 6:30:50 AM(UTC)
GE Microwave not heating (Microwave Repair)
by darrelljpark 10/23/2012 9:04:46 PM(UTC)
by kamran 8/29/2012 10:21:34 PM(UTC)
microwave not heating (Microwave Repair)
by kdanley30 3/3/2012 7:22:44 AM(UTC)
by dgeerts5@yahoo.com 12/1/2011 3:34:00 PM(UTC)
Built-in Microwave not heating (Microwave Repair)
by travois 11/4/2011 10:15:10 AM(UTC)
by Debbieandlouie 9/7/2011 6:14:05 AM(UTC)
Goldstar Microwave not Heating! (Microwave Repair)
by nufam77 8/2/2011 8:26:14 AM(UTC)
