travois
#1 Posted : Friday, November 4, 2011 10:15:10 AM(UTC)
travois
I had the microwave on for 6 minutes without anything inside. I meant to use the timer and turned it on instead. Now it will not heat. Everything is working except there is not heat. Is this a Magnetron issue? If so, how and where in the Sacramento area can it get repaired? Can I order the part myself and replace it myself? What is the cos?
donjo
#2 Posted : Tuesday, November 8, 2011 3:53:13 PM(UTC)
donjo
I have a GE Spacesaver microwave that will not heat and turntable will not turn. The timer will run, clock works ,lights work but no heat. Would this be a magnetron? I would like to fix this my self if I new where to look. Do you know where I can get a schmetic showing internal parts. The model numberis JVM1340AW002 it is a built in over the stove model.
