mtrybe
#1 Posted : Wednesday, December 7, 2011 7:38:32 PM(UTC)
mtrybe
my gas dryer runs and blows cold air out exhaust vent. the flame switch or igniter does not glow and no voltage across terminal. the igniter was tested and said to be functional. it was replaced A year ago. do you have a wiring diadram and/or troubleshooting recommendations
ApplianceJunk
#2 Posted : Wednesday, December 7, 2011 7:46:37 PM(UTC)
ApplianceJunk
Could not find a wiring diagram, but if you don't have voltage to the ignitor I would check the thermal fuse on the blower housing. You will have to remove the front of the dryer to access it. Not 100% if this thermal fuse kills the dryer if it's bad or just the burner, but it's easy enough to check.
This is what it should look like on your model. If it's bad it will check open or no continuity with a ohm meter.
WHIRLPOOL Cut - Off - T, part number: AP4037135
mtrybe
#3 Posted : Thursday, December 8, 2011 7:09:48 PM(UTC)
mtrybe
this is model DG612 Series 2. According to the parts diagram the thermal fuse starts with series 7. the blower housing contains two cycling thermostats each with 3 electrical terminals that appear to be wired in parallel. there also is a high limit thermostat on the burner assembly. would a problem with any of these items prevent lighting of the igniter? how would one test these thermostats with three terminals(two opposite one)?
gas dryer wont heat (new coils, igniter glows) (Dryer Repair)
by ajpa 5/30/2012 8:58:27 AM(UTC)
Gas dryer wont heat up (Dryer Repair)
by kramler92 12/8/2011 3:14:26 PM(UTC)
Whirlpool gas dryer wont heat. (Dryer Repair)
by Ray3059 9/16/2010 7:18:59 PM(UTC)
jenn-air natural gas dryer wont heat (Dryer Repair)
by oneokangel 9/30/2009 2:54:15 PM(UTC)
Whirlpool Imperial series gas dryer wont heat up.. (Dryer Repair)
by NBK 4/6/2009 3:36:45 PM(UTC)
by yertle11 1/7/2009 7:01:50 PM(UTC)
Amana gas dryer wont heat (Dryer Repair)
by juggler 11/27/2008 2:44:53 PM(UTC)
my kenmore elite gas dryer wont heat (Dryer Repair)
by helpmeoutplz 9/8/2008 9:22:16 AM(UTC)
