davepechkis
#1 Posted : Tuesday, December 6, 2011 6:50:08 PM(UTC)
davepechkis
I have a Kitchenaid electric range and the bake and broil elements won't heat. I found an open 20A fuse in the back of the range. I tested to see if there are any shorts to ground starting at the fuse (inside heatshrink tubing about 6" from the terminal block) all the way to the control panel. The elements are not shorted to ground nor are there any damaged wires. I removed and inspected the control panel but no problems were visible. The thermal fuse below the control panel is ok. Does anyone have any suggestions? I would expect to find a short to groud to cause the fuse to open. Has anyone had a control board problem cause the fuse to open? My oven light does not turn on but it's had intermitant operation for quite some time with no effect on oven operation. I have no errors on the display and I hear the doubler relay activate when the oven is turned on. I can also see the contacts close on the bake relay located on the control panel.
ApplianceJunk
#2 Posted : Tuesday, December 6, 2011 7:18:34 PM(UTC)
ApplianceJunk
I have had that fuse blow for no good reason. I would just replace the fuse and give it a try.
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
oven does not heat but stove works control panel works (Oven Repair (including Ranges and Cooktops))
by asfimag 11/10/2012 7:02:45 AM(UTC)
GE True Temp Electric Oven does not heat (Oven Repair (including Ranges and Cooktops))
by ksdavis1121 10/4/2012 11:43:04 AM(UTC)
Frigidaire oven does not heat (Oven Repair (including Ranges and Cooktops))
by camliv 9/30/2012 6:40:11 PM(UTC)
by camliv 9/30/2012 6:35:43 PM(UTC)
by escobedo55 3/11/2012 5:08:15 PM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
by fred08 9/2/2011 3:10:27 AM(UTC)
by smedleybr 7/14/2011 12:01:02 PM(UTC)
by tunnelwise 6/14/2011 12:41:11 PM(UTC)
oven does not heat to correct temp (Oven Repair (including Ranges and Cooktops))
by wawpooh 3/8/2011 11:54:18 AM(UTC)
oven does not heat up (Oven Repair (including Ranges and Cooktops))
by candyburch 2/4/2011 2:33:48 PM(UTC)
Oven Does Not Heat Up (Oven Repair (including Ranges and Cooktops))
by JIM1955 2/4/2011 6:23:20 AM(UTC)
