Al17
#1 Posted : 13 years ago
Al17
Disconnecting and taking out Ice maker from freezer will this cause an issue? Ice maker has never been used and not water hoooked up to it.
ApplianceJunk
#2 Posted : 13 years ago
ApplianceJunk
Disconnecting and taking out Ice maker from freezer will not effect how your refrigerator works.
May I ask why you want to remove it?
Al17
#3 Posted : 13 years ago
Al17
It just gives me more room in the fridge since its not used. My fridge is not cooling up top i have to defrost fins to get it to cool again. Ive had to do this 2 times already. hoping that removing the ice maker wasn't causing this issue even though i took it out after this occured. do you have an idea of what it could be?
ApplianceJunk
#4 Posted : 13 years ago
ApplianceJunk
Sounds like you may have a defrost problem. Your refrigerator is a self defrosting model and should defrost itself so you don't have to.
The ice maker has nothing to do with the defrost system on this model refrigerator.
The defrost system on your model is run by the control board.
WHIRLPOOL Cntrl - Elec, part number: AP4366538
The control board turns on the defrost heater in the freezer.
WHIRLPOOL Heater, Evaporator, part number: AP4078863
Once the frost has been melted the defrost thermostat/Bi metal kills power to the heating element.
WHIRLPOOL Bimetl - Def, part number: AP4310486
Al17
#5 Posted : 13 years ago
Al17
I had this issue when i first got the unit. the Jazz board and thermostat were replaced. is the Jazz board the contrl board? is this simple to replace? Once i defrost the fins the fridge works good untill about a montg later when i have to do this again.
ApplianceJunk
#6 Posted : 13 years ago
ApplianceJunk
Yes it is the same board.
I have no idea how handy you are, but I feel it's a fairly simple part to replace.
Al17
#7 Posted : 13 years ago
Al17
Is the board in the fridge on the top by the lights? I'm a tech so i should be able figure it out..
Are the control boards a common issue? how else can i test to make sure that is the problem not something else? thanks for the help by the way..
ApplianceJunk
#8 Posted : 13 years ago
ApplianceJunk
Yes it is.
They have been for me.
Here is a copy of the tech sheet for your model refrigerator.
It includes some troubleshooting information that you may find helpful.
File Attachment(s):
Tech Sheet - 12827967.pdf (427kb) downloaded 6 time(s).
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 10 months ago
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 10 months ago
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 10 months ago
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 11 months ago
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest about a year ago
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 about a year ago
Ice maker slabbing (Refrigerator & Freezer Repair)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 about a year ago
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 about a year ago
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla about a year ago
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 about a year ago
Ice maker fiil/dump (Refrigerator & Freezer Repair)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw about a year ago
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay about a year ago
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 about a year ago
