Blanchet
#1 Posted : Tuesday, February 3, 2009 8:37:09 AM(UTC)
Blanchet
Water is dispensing, but not into the freezer tray. Water goes into cube collector tray.
#2 Posted : Wednesday, February 4, 2009 4:00:25 PM(UTC)
Most likely the water tube has been dislodged.
Blanchet
#3 Posted : Wednesday, February 4, 2009 6:46:27 PM(UTC)
Blanchet
Water tube is not dislodged. It comes through the back of the refrigerator and hangs over the cup that should direct water to freezing tray. It does not hang over by much. Should there be an elbow fitting on the end of water tube? I used a plastic barbed elbow, but then ice formed in the elbow.
#4 Posted : Thursday, February 5, 2009 1:41:40 PM(UTC)
Check if the tube looks like the one on the picture bellow:
UserPostedImage
Here are the break down diagrams for the Frigidaire refrigerator Model FPES18TCA0
Blanchet
#5 Posted : Thursday, February 5, 2009 2:20:28 PM(UTC)
Blanchet
UserPostedImage
This looks like part #56 in the diagram. What I have looks like #55. I assume #56 attaches to #55, so I ordered one. Thanks Gene
#6 Posted : Thursday, February 5, 2009 3:56:08 PM(UTC)
#55 tube goes through the back wall from outside, #56 tube attached to the #55 inside the freezer and goes into the ice maker. Keep us posted.
Blanchet
#7 Posted : Sunday, March 8, 2009 3:57:35 PM(UTC)
Blanchet
The part you suggested worked fine. All is well. Thank you
#8 Posted : Sunday, March 8, 2009 5:58:08 PM(UTC)
You are welcome. We are glad you were able to fix it.
Whirlpool Side by Side with icemaker Model WRS588FI (Refrigerator & Freezer Repair)
by Guest 4/19/2024 4:08:15 PM(UTC)
Whirlpool WRS325SDHB08 Icemaker works intermittently (Refrigerator & Freezer Repair)
by donl1150 3/2/2024 5:04:55 AM(UTC)
Kennmore icemaker does not work (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:57:24 AM(UTC)
ICEMAKER ISSUE: Kitchenaid KSRS27QFAL00 Superba (Refrigerator & Freezer Repair)
by jselko 10/14/2023 1:30:11 PM(UTC)
Icemaker for Kenmore 106.51764510 (Forum Announcements)
by jzannini 9/26/2023 12:37:24 PM(UTC)
Why do the prices of IceMaker Cycling Thermostats VARY so much? (Refrigerator & Freezer Repair)
by Mark531 9/6/2023 2:17:44 PM(UTC)
GE refrigerator icemaker freezing up (Refrigerator & Freezer Repair)
by Guest 7/1/2023 6:40:00 AM(UTC)
MFI2269VEM2 icemaker quit (Refrigerator & Freezer Repair)
by Smoreschnapps 5/22/2023 7:06:31 AM(UTC)
GE Undercabint Icemaker (Refrigerator & Freezer Repair)
by rjcunning 4/9/2023 7:35:53 AM(UTC)
no noise when push buttons on icemaker to dispense ice (Refrigerator & Freezer Repair)
by Messenger12 2/27/2023 3:06:18 AM(UTC)
New icemaker failed (Refrigerator & Freezer Repair)
by 7Pat 12/18/2022 11:40:20 AM(UTC)
Buy (200 Pcs) New Insignia - 44 Lb. Portable Nugget Icemaker $39,800 (General Talk)
by eikohajime30 11/9/2022 10:16:55 PM(UTC)
Icemaker Voltage at freezer wire harness (Refrigerator & Freezer Repair)
by mcouvillon 11/1/2022 8:37:12 AM(UTC)
Whirlpool Icemaker NO-OP (model WSF26C3EXF01) (Refrigerator & Freezer Repair)
by Lynster 10/10/2022 2:52:08 PM(UTC)
sub zero icemaker uc15 (Refrigerator & Freezer Repair)
by Guest 9/25/2022 7:21:16 AM(UTC)
