DANLUDLOW
#1 Posted : Monday, November 28, 2011 7:28:09 AM(UTC)
DANLUDLOW
For the past few months microwave was intermittently making a humming noise during operation. Now the microwave stopped making the noise but is not warming food as it used to do. It takes longer periods of time for the food to warm. What is causing this problem?
#2 Posted : Monday, November 28, 2011 1:06:14 PM(UTC)
Most likely the problem is a bad magnetron, but there is a small chance that the 1100W inverter (#21 on the diagram) is bad as well. I would replace the magnetron first.
- The magnetron Part number: AP3881382
DANLUDLOW
#3 Posted : Monday, November 28, 2011 3:06:31 PM(UTC)
DANLUDLOW
Does the magnetron come with installation instructions? Can you give me a link for the magnetron installation instructions?
#4 Posted : Monday, November 28, 2011 4:47:49 PM(UTC)
As soon as you will remove the microwave from the cabinet and remove the outer case, you'll see how simple it is.
DANLUDLOW
#5 Posted : Tuesday, November 29, 2011 4:33:55 AM(UTC)
DANLUDLOW
I know I need to unplug the microwave during this repair. Do I need to be concerned about high voltage while replacing the magnetron?
#6 Posted : Tuesday, November 29, 2011 3:24:04 PM(UTC)
Yes. It has to be discharged. The instructions are attached to the reply.
File Attachment(s):
DANLUDLOW
#7 Posted : Wednesday, November 30, 2011 4:46:50 AM(UTC)
DANLUDLOW
Thank you for the discharging instructions. Do I also need to discharge the 1100 watt inverter board if I'm only replacing the magnetron? Do I discharge both terminals on the magnetron? From the instructions that you sent for discaharging the 1100 watt inverter board it looks like you use needle point pliers to discharge thru a resistor correct? If pliers are used; how do you recommend that I ground the pliers and to what? Can you send some instructions on how to test the magnetron with a voltage meter?
#8 Posted : Wednesday, November 30, 2011 2:01:20 PM(UTC)
If the microwave has been unplugged for more than an hour it probably does need any discharging.
There is no any reliable instrumental test for the magnetron. That's why I mentioned two parts which could cause such problem.
Microwave repair (Microwave Repair)
by Tim Swanson 11/20/2013 1:20:16 PM(UTC)
by Burde Kamath 2/11/2013 4:08:13 AM(UTC)
Is this microwave repairable (Microwave Repair)
by kalt 12/31/2012 9:41:35 AM(UTC)
Microwave Repair (Microwave Repair)
by ramara 12/4/2012 1:13:52 PM(UTC)
microwave repair help (Microwave Repair)
by dia 10/1/2012 1:08:16 PM(UTC)
by gskill@bellsouth.net 8/1/2012 3:21:05 AM(UTC)
by JO D 12/11/2011 4:17:55 AM(UTC)
microwave repair (Microwave Repair)
by cking1269 11/4/2011 9:04:36 AM(UTC)
kenmore microwave repair (Microwave Repair)
by ploou 11/3/2011 10:42:00 AM(UTC)
GE microwave repair help (Microwave Repair)
by Tom in Crozet 4/28/2011 7:07:55 PM(UTC)
Microwave Repair with loud noise (Microwave Repair)
by Faith4220 12/26/2010 11:20:14 AM(UTC)
by stillyrabbit 12/22/2010 10:52:18 AM(UTC)
by bloop 11/4/2010 8:33:04 AM(UTC)
Is old microwave repairable? (Microwave Repair)
by sadiehaflinger 11/17/2009 9:51:36 AM(UTC)
by allene 10/12/2009 7:58:42 AM(UTC)
