Sutherland
#1 Posted : Monday, November 28, 2011 11:47:24 AM(UTC)
Sutherland
GE Profile Clothes washer: Used only 4 months, but machine 4 years old and has been shipped to Dominica where there are no GE repairmen or parts. Can use electronic controls but have to keep resetting by holding down start/stop button for 10 seconds and then all the time the washer is working, it is beeping -- most annoying. Screen wants to default to My Cycles instead of main screen. Is all this likely a failure of the mother board or is it possibly caused by something else? Is it on its way out or likely just something that could be lived with?
The mother board part # is 385OEA4011A, but GE doesn't recognize this. From its diagram, I get a WH12X10282 as likely part #. GE lists this as $492
Many thanks,
Karen
sidfink43
#2 Posted : Tuesday, November 29, 2011 4:59:02 PM(UTC)
sidfink43
It does sound like the main control board, and given its cost and the general unreliability of this machine I strongly recommend not fixing it.
Try to live with it as long as you can, and then see if you can replace it with a good basic new or used top loader. The less bells and whistles, the better.
Good luck
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
Replace the main control panel? (Microwave Repair)
by Guest 10/25/2021 7:11:40 AM(UTC)
line voltage in old Whirlpool control panel? (Dishwasher Repair)
by Paul_illinois 2/19/2014 7:40:06 AM(UTC)
Can I test a Control Panel? (Oven Repair (including Ranges and Cooktops))
by opeter 11/6/2013 9:27:43 AM(UTC)
Is it bad that there is debris under my control panel? (Dishwasher Repair)
by abahan 8/22/2013 2:18:18 PM(UTC)
I fixed one problem, but did I fry control panel? (Oven Repair (including Ranges and Cooktops))
by friendly_jacek 12/15/2012 7:04:22 PM(UTC)
Maytag Dishwasher quietseries 200 control panel? (Dishwasher Repair)
by Maytagwhat? 12/12/2012 6:52:42 PM(UTC)
Element or control panel? (Oven Repair (including Ranges and Cooktops))
by gettmac 1/23/2012 2:50:03 PM(UTC)
Maytag won't fill. Valve or Control panel? (Dishwasher Repair)
by tdfaber 10/1/2011 1:21:37 PM(UTC)
How do I replace the electronic control panel? (Washer Repair)
by AWC 9/7/2011 9:12:30 AM(UTC)
Replace control panel? (Dishwasher Repair)
by merple 6/8/2011 10:41:51 AM(UTC)
Control board or control panel? (Oven Repair (including Ranges and Cooktops))
by Julie0012 5/19/2011 6:00:45 AM(UTC)
control panel? (Dryer Repair)
by guyfino 2/4/2011 7:35:28 AM(UTC)
Kitchenaid Dw: Need New Control Panel? (Dishwasher Repair)
by chipLAT8706 11/5/2010 12:31:07 PM(UTC)
remove control panel? (Oven Repair (including Ranges and Cooktops))
by rhwebb 9/30/2010 4:21:20 PM(UTC)
