Maytag mdb9100awb Fill valve appears to be bad. Voltage measures 101v. Is it possible that this is a control panel problem? Shouldn't voltage be 110-120v? Water Supply is OK. Filters are clean. Float valve is not stuck.
Check the voltage at the plug or where the line is connected to the unit. The fill valve should get this voltage.
Disconnect the valve and check the voltage across the wires to the valve when it is supposed to be filling. Could be that a bad valve is dropping your supply voltage.
by "Filters are clean" I am assuming you mean the screen filter on the input side of the water valve. |
THIS FORUM IS DEAD!!!!!!! |
