shlomo
#1 Posted : Tuesday, January 27, 2009 4:32:36 PM(UTC)
shlomo
Does anyone know what would cause my Kenmore DW to stick on "sensing" when turned on?
After a short while - it makes a humming noise like there is current draw but know action.
It starts humming the time the pump usually kicks in.
Motor - Capacitor - Sensor - All 3?
Thanks in Advance ~
Rob
#2 Posted : Wednesday, January 28, 2009 5:23:39 PM(UTC)
Hi Rob,
The first thing I would do is check for a foreign objects inside the pump and the chopper assembly. You can find the complete instructions in one of our previous posts: http://forum.appliancepartspros...hirlpool-dishwasher.html
shlomo
#3 Posted : Tuesday, February 3, 2009 5:42:11 AM(UTC)
shlomo
Gene ~
Thanks for your help - AGAIN!
You have saved me quite a bit of money with your technical expertise.
I had to replace the motor/pump assembly on my Kenmore/Whirlpool DW.
The motor was very corroded and the fault of the unit. What will prevent the new motor from being corrupted in the same way as the OEM? Within 3 years? This is more of a Kenmorw response.
Thanks again!
Rob
#4 Posted : Tuesday, February 3, 2009 8:16:15 PM(UTC)
You are welcome. We are glad you were able to fix it.
