Stevo40
#1 Posted : Saturday, January 31, 2009 11:27:10 PM(UTC)
Stevo40
I unpluged the fridge and left the freezer door open due to ice build up in the coils. The evaporator fan is not running at all even after defrosting the unit. Cleaned underneath fridge for dust and debris. Condenser fan is working fine. After defrosting the system, items in the freezer section is getting back to normal, but took some time to freeze. Now I don't know whether it is the evaporator fan or the defrosting system. Please assist.
#2 Posted : Sunday, February 1, 2009 4:13:18 AM(UTC)
Model FRT18HS6DWC
You may have 2 problems.
1. FAN
Measure across the motor for voltage. If you have 120 volts AC and the motor does not turn it is shot
OR
Unplug the unit and the motor. Measure across the motor for resistance, if it is an open (infinite resistance) the motor is shot.
2. DEFROST
Your defrost timer is mounted under the cover at the top of the fresh food section (Item 23 in the "Shelves" section). Actual part in the list is at the bottom of the list (F23). There should be a hole in the cover which will allow you to rotate the timer cam with a screw driver. It only rotates in one direction so do not force it. Rotate the cam till the compressor fan goes off. You should now be in defrost mode.
Does the defrost heater get hot? Be careful do not burn your fingers.
Note the defrost thermostat must be frozen, it opens and will shut off the heater just above 32 degrees.
If it does heat up you know that the heater and the thermostat are OK.
Let it run in defrost mode. It should finish the defrost cycle in half an hour or so. If not odds are high the timer is shot, cam not rotating.
This does not rule out the timer totally could be the the contacts in the timer are not closing or it is jamming up somewhere else in it's rotation.
icehouse
#3 Posted : Sunday, February 1, 2009 5:16:56 AM(UTC)
icehouse
I remember in the early seventies, Mars sold a kit. Heater, defrost thermostat, timer. Boss use to say if one failed, others not far behind. :)
Stevo40
#4 Posted : Sunday, February 1, 2009 11:06:49 PM(UTC)
Stevo40
I turned the defrost timer with a flat head screwdriver and it cut off and came back on after about 25 mins. Heater was warm to touch, ice indeed defrosted. Not sure on how to do the attack your first reply about the voltage. But, the fan did turn with my finger without any force. I was hoping that after it defrosted the fan would come back on but, no luck. So, does this mean that it may just be the evaporator fan? Or, if the fan was bad, would that make the defrost timer not work also?
Maybe I need both parts? Please assist
#5 Posted : Monday, February 2, 2009 2:41:18 AM(UTC)
You will need a multimeter to do either check.
Could try just replacing the fan if you do not have a meter
Yes
No
I would replace the fan first and see how it goes
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
icehouse
#6 Posted : Monday, February 2, 2009 3:46:37 AM(UTC)
icehouse
Question : Does this mean the evaporator fan is bad ?
Answer : Did you let the unit run long enough for the defrost limit to close, around 25*F coil temperature. The defrost limit acts also as a fan delay, and until it closes the fan will not run.
Stevo40
#7 Posted : Wednesday, February 18, 2009 6:37:21 PM(UTC)
Stevo40
Hey Denman, finally got the evaporator fan, yesterday, hooked it up and heard the greatest sound in about 3 weeks. The sound of a fan and cold air going into my refrigerator compartment. I just wanted to say thankyou and Icehouse for your reply with my fridge. I was wondering will your website eventually have a way to input several address that one may want a part to be shipped to? Glad to see you feeling better. Lon told me you were out sick last week.
#8 Posted : Wednesday, February 18, 2009 6:54:50 PM(UTC)
Glad it is fixed
You're welcome, always nice to get a thank you
As to multiple addresses I have no idea I just volunteer here.
icehouse
#9 Posted : Thursday, February 19, 2009 4:26:23 AM(UTC)
icehouse
Originally Posted by: denman Go to Quoted Post
Glad it is fixed
What he said. :)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Refridgerator keeps running - thermostat bad? (Refrigerator & Freezer Repair)
by PatInPA 4/17/2024 1:53:30 PM(UTC)
Kenmore Elite Refridgerator 795.799773.903 (Refrigerator & Freezer Repair)
by Rick_Titus 10/7/2023 4:28:57 PM(UTC)
Kenmore Elite Refridgerator control panel not working (Refrigerator & Freezer Repair)
by Guest 10/3/2023 10:18:35 AM(UTC)
Whirlpool Refridgerator GD5SHAXLQ02 - Freezer too warm (Refrigerator & Freezer Repair)
by Guest 3/1/2022 11:17:14 AM(UTC)
thermostat issues in maytag refridgerator (Refrigerator & Freezer Repair)
by someguy78 2/26/2022 7:58:31 AM(UTC)
Fridgedaire Refridgerator FRS241 (Appliance Parts)
by Dremcatcr 1/23/2022 11:15:03 AM(UTC)
GE gsh25jfxbww refridgerator (Refrigerator & Freezer Repair)
by David Heath 11/13/2021 4:10:59 AM(UTC)
Whirlpool refridgerator repair (Refrigerator & Freezer Repair)
by HectorMartinez 10/8/2021 12:22:46 AM(UTC)
Whirlpool Refridgerator (Refrigerator & Freezer Repair)
by mikecain01 10/7/2020 3:37:19 AM(UTC)
ge refridgerator not working (Refrigerator & Freezer Repair)
by geno630 9/10/2020 11:57:49 AM(UTC)
Freon leak in Viking refridgerator...repairable? what else can i do? (Refrigerator & Freezer Repair)
by viper_gts 7/29/2020 7:29:30 AM(UTC)
GE Refridgerator model PSS25NGNAWW (Refrigerator & Freezer Repair)
by shuskey450 7/18/2020 9:24:05 AM(UTC)
refridgerator section is not cold enough (Refrigerator & Freezer Repair)
by androidx1 6/8/2020 9:38:34 AM(UTC)
Fan Constantly Running on Viking Refridgerator (Refrigerator & Freezer Repair)
by deeni 4/7/2020 5:09:06 AM(UTC)
