buraggie
#1 Posted : Saturday, November 19, 2011 6:06:07 PM(UTC)
buraggie
my neptune washer made a loud noise during the wash cycle and blew a circuit breaker. When I reset the breaker, there was no power to the washer (the control was blank). I plugged it into another outlet and made sure it was hot, but still no power to the control panel. I had to pull the green emergency "string" to open the door and get clothes out. Any idea what failed? I first thought that it was the motor control board, but would this kill the control panel?
sidfink43
#2 Posted : Sunday, November 20, 2011 4:50:14 PM(UTC)
sidfink43
If you are getting power to the control board but nothing happens then the control board is the first place to look for the problem. Use a meter to make sure you have current at the control unit.
buraggie
#3 Posted : Monday, November 21, 2011 5:28:58 PM(UTC)
buraggie
i have 120v to the control board and 24V and 5V coming out of the transformer. I don't see any obvious burns on the cirduit board. The motor control board also looks undamaged and all three motor ohms check out OK. Any ideas?
sidfink43
#4 Posted : Monday, November 21, 2011 5:45:48 PM(UTC)
sidfink43
Here is a link to the service manual for your unit which will tell you how to do testing and what the voltages should be
https://docs.google.com/viewer?a...jRkZTQ1OWNm&hl=en_US.
Your model is covered in detail at the back of the manual, it just doesn't say so in the table of contents.
