kelljern
#1 Posted : Sunday, November 20, 2011 12:21:40 PM(UTC)
kelljern
I have an Amana oven the beside the clock the word OFF is lite up red.
Oven will not come on and none of the buttons work.
Is this repairable and is it worth the repair? What part is needed to make the repair. Is it easy to replace?
Kellie
kelljern@aol.com
#2 Posted : Monday, November 21, 2011 8:44:02 AM(UTC)
Could be the child lock is on.
Here is the operator's manual
https://www.maytag.com/digitalas...Guide%20-%2031786101.pdf
See page 16.
Amana oven (insert) turns off (Oven Repair (including Ranges and Cooktops))
by Melodyportillo 12/29/2019 10:12:09 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
How to access amana oven door latch (Oven Repair (including Ranges and Cooktops))
by Handyguy1 9/30/2015 7:39:03 PM(UTC)
Amana oven not heating (Oven Repair (including Ranges and Cooktops))
by myrnarud 9/24/2014 7:15:11 PM(UTC)
Amana Oven/Range Fuse? (Oven Repair (including Ranges and Cooktops))
by sashko 3/20/2014 1:45:41 PM(UTC)
how do I replace relay board on amana oven (Oven Repair (including Ranges and Cooktops))
by ghappe 11/4/2013 11:30:31 AM(UTC)
Amana Oven Fails after Power Failure (Oven Repair (including Ranges and Cooktops))
by newatappliancerepair 2/4/2013 9:05:57 PM(UTC)
Amana Oven Problem (Oven Repair (including Ranges and Cooktops))
by JOHN S. 1/10/2013 5:50:09 PM(UTC)
Amana oven temp keeps climbing then display goes out (Oven Repair (including Ranges and Cooktops))
by Jovian66 12/26/2012 6:20:27 PM(UTC)
Amana oven smells of LP after oven is off (Oven Repair (including Ranges and Cooktops))
by m22214 11/13/2012 2:01:34 PM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
Amana oven won't heat properly (Oven Repair (including Ranges and Cooktops))
by azace 7/14/2012 1:24:16 PM(UTC)
Amana oven not getting hot? (Oven Repair (including Ranges and Cooktops))
by bipinsen 4/17/2012 8:40:47 AM(UTC)
Amana Oven Not Working (Oven Repair (including Ranges and Cooktops))
by brijets 12/20/2011 5:12:15 AM(UTC)
Amana Oven F9 error (Oven Repair (including Ranges and Cooktops))
by Creston 12/7/2011 5:56:40 AM(UTC)
