My freezer has ice build up at the beck panel. May I know what needs to be replaced
My freezer has an ice build up at the back section and it does not freeze the food inside. I want to know what replacement part to order? Thanks
My freezer has an ice-build-up at the back. It does not freeze the foods inside. May i know what part to order? Thank you
Originally Posted by: conrado  My freezer has ice build up at the beck panel. May I know what needs to be replaced We are having the same problem with a GE fridge. Need to know what needs to be replaced also.
