springwash
#1 Posted : Tuesday, January 27, 2009 5:51:50 PM(UTC)
springwash
Recently had to change spin belt on washer because piece of clothing got caught above drum during spin cycle causing the drum not spin and belt to burst. After changing belt I only hear ticks from timer when water is supposed to be draining. I am thinking that either the switch or a relay? got burnt because of the drum not spinning or the water pump is dead. Any advise would be appreciated.
Regards
springwash
#2 Posted : Tuesday, January 27, 2009 7:37:07 PM(UTC)
springwash
Just a followup note: The washer seems to fill with water correctly initially, agitates and spins, just does not seem to fill anymore water for rinse or drain water after initial wash
#3 Posted : Wednesday, January 28, 2009 6:01:09 PM(UTC)
Check the belt tension. Possible a clog in the pump.
Here are the break down diagrams for the Maytag washer Model SAV3655AWW
springwash
#4 Posted : Wednesday, January 28, 2009 6:20:41 PM(UTC)
springwash
Pump seems okay as when I remove hose from side that goes to drain water spews out. If the drum is spinning and agitating would that not mean that the belt tension was okay? Is the motor supposed to spin a different direction when in the rinse/wash cycle vs. when the water is draining? Currently the motor only seems to spin in a counter clockwise direction which seems to be the correct direction for water drainage.
#5 Posted : Thursday, January 29, 2009 4:48:39 AM(UTC)
These should help
http://www.servicematters.com/m...ibrary/docs/16022937.pdf
http://www.servicematters.com/m...ibrary/docs/16022615.pdf
Motor should change direction for agitate and spin.
During spin the water is pumped out.
Gravity by itself will do this.
Check the drain hose for a clog, unlikely but a possibility.
Remove the pump and check it. Could be the impeller is broken.
Normally yes, if it acheives a high spin speed
No, Agitate and spin changes direction
Do not think unit would do both agitate and spin, if it will only run in one direction
Water does not drain completely (Dishwasher Repair)
by g11171 9/17/2012 5:28:01 PM(UTC)
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 6/23/2012 7:09:22 PM(UTC)
Washer spins but water does not drain (Washer Repair)
by Ed Marshall 6/7/2011 2:44:45 AM(UTC)
Water does not drain at proper time (Washer Repair)
by Doug109 12/14/2009 3:57:38 PM(UTC)
water does not drain all out on the spin cycle (Washer Repair)
by lavete 9/12/2009 6:06:39 AM(UTC)
water does not drain completely (Refrigerator & Freezer Repair)
by cgmyers 9/7/2009 5:32:07 PM(UTC)
Water does not drain (Washer Repair)
by jtancsi1 7/26/2009 1:32:45 PM(UTC)
Water does not drain (Dishwasher Repair)
by solson 1/29/2009 6:22:41 AM(UTC)
Water Does Not Drain Unless Extra Spin Cycles (Washer Repair)
by chief455 10/19/2008 9:52:53 AM(UTC)
