Cycle runs but all the water does not drain completly.
Kinked drain hose. Probably where it goes thru cabinet to under sink. Able to force water thru, but not the last bit.
More than likely a clog ... I have found 90% of clogs in the air gap or the hose leading from the air gap to the gabage disposal ... Not very common to find a kink in the drain line from the diswasher to the air gap,for it is designed not to kink.
