cgmyers
#1 Posted : Monday, September 7, 2009 5:32:07 PM(UTC)
cgmyers
Cycle runs but all the water does not drain completly.
DanielK
#2 Posted : Tuesday, December 1, 2009 6:00:06 PM(UTC)
DanielK
Kinked drain hose. Probably where it goes thru cabinet to under sink. Able to force water thru, but not the last bit.
gabe_1981
#3 Posted : Tuesday, December 1, 2009 6:08:25 PM(UTC)
gabe_1981
More than likely a clog ... I have found 90% of clogs in the air gap or the hose leading from the air gap to the gabage disposal ... Not very common to find a kink in the drain line from the diswasher to the air gap,for it is designed not to kink.
Water does not drain completely (Dishwasher Repair)
by g11171 9/17/2012 5:28:01 PM(UTC)
