Sandie RPlease start your own thread using "Post New Topic" unless the model and the problem are the same.
Sandi Van CampHere are your parts
Replacement parts for WHIRLPOOL GEW9200LW1 Electric Dryer | AppliancePartsPros.comSee the attachment for the tech sheet.
First check the power to the unit. The heating coils require the full 240 volts but the motor and control board only require half the line (120volts)
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR] Next would be the heating coil itself, should be 8 to 12 ohms.
Then the thermal cut-off and high limit thermostat, both should be 0 ohms.
Then the thermistor, about 10,000 ohms at room temperature.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
