Sandi Van Camp
#1 Posted : Saturday, November 12, 2011 7:48:08 PM(UTC)
Sandi Van Camp
The electric dryer does not seem to heat up. It seems to operate okay otherwise
Sandie R
#2 Posted : Sunday, November 13, 2011 6:31:53 PM(UTC)
Sandie R
Hopefully someone can guide us to the correct part. :)
#3 Posted : Monday, November 14, 2011 9:14:49 AM(UTC)
Sandie R
Please start your own thread using "Post New Topic" unless the model and the problem are the same.
Sandi Van Camp
Replacement parts for WHIRLPOOL GEW9200LW1 Electric Dryer | AppliancePartsPros.com
First check the power to the unit. The heating coils require the full 240 volts but the motor and control board only require half the line (120volts)
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Next would be the heating coil itself, should be 8 to 12 ohms.
Then the thermal cut-off and high limit thermostat, both should be 0 ohms.
Then the thermistor, about 10,000 ohms at room temperature.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
GEW9200.pdf (327kb) downloaded 33 time(s).
Whirlpool Duet electric dryer model WED8300SW1 (Dryer Repair)
by Guest 9/9/2023 9:26:30 AM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
Whirlpool Duet electric dryer overheats despite replacing various parts (Dryer Repair)
by Manec 8/18/2016 6:49:44 PM(UTC)
Whirlpool Duet Electric Dryer Won't Do anything (Dryer Repair)
by mbe5003 11/30/2014 1:49:35 PM(UTC)
Whirlpool Duet electric dryer drum not turning (Washer Repair)
by drmjtn 11/2/2014 7:52:05 AM(UTC)
Whirlpool Duet Electric Dryer (Dryer Repair)
by Kaymardixie 7/15/2014 3:58:29 PM(UTC)
whirlpool duet electric dryer no heat (Dryer Repair)
by Reisingera03 2/6/2013 2:49:42 PM(UTC)
Whirlpool Duet Electric Dryer won't get hot (Dryer Repair)
by lisaal 10/30/2012 5:43:42 PM(UTC)
whirlpool duet electric dryer does not heat (Dryer Repair)
by alxholbrook 9/28/2012 6:21:38 AM(UTC)
Whirlpool Duet Electric Dryer does not turn on (Dryer Repair)
by vong 11/3/2011 5:30:28 PM(UTC)
Whirlpool Duet electric dryer wont start (Dryer Repair)
by miketieman 6/20/2011 8:40:50 AM(UTC)
whirlpool duet electric dryer works but no heat (Dryer Repair)
by sbfire370 4/13/2011 3:24:11 AM(UTC)
