c strain
#1 Posted : Friday, January 23, 2009 11:27:18 AM(UTC)
c strain
Just One Day The Dryer Would Not Turn On. I Checked The Breaker And Tested The Outlet So It Seems To Be The Dryer
SublimeMasterJW
#2 Posted : Friday, January 23, 2009 12:37:35 PM(UTC)
SublimeMasterJW
The fuse is mounted on the rear of the dryer. To get to it pop the top The fuse is held to the right hand side of the heat chamber, it has 2 white wires going to it and the same screw that holds down the heater itself also holds that fusePC150439.jpg
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : Friday, January 23, 2009 12:40:51 PM(UTC)
SublimeMasterJW
Start by popping the top:
Removing the speed control board.doc (227kb) downloaded 14 time(s).
SublimeMasterJW
#4 Posted : Friday, January 23, 2009 12:45:09 PM(UTC)
SublimeMasterJW
This dryer will sometimes gets a big ball of lint in the filter housing. The blower will get loose and make it take a long time to dry clothes. So check for a lint ball and a loose blower. Dont forget the vent:
gbs18hbpbww.jpg OOPZ!!!:D
c strain
#5 Posted : Saturday, January 24, 2009 4:54:33 PM(UTC)
c strain
how can i tell if the fuse is bad? do you have a diagram of the whole bakc of the dryer because i do not know what any of the parts are
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer wont start (Dryer Repair)
by rscottc 5/27/2018 10:49:05 PM(UTC)
maytag dryer wont start (Dryer Repair)
by clavin29 3/1/2014 7:22:21 AM(UTC)
Maytag dryer wont start (Dryer Repair)
by Rich8529 6/25/2012 4:46:37 PM(UTC)
by stan568 1/24/2008 2:32:38 PM(UTC)
