Keypad was getting erratic at times. Progressively got worse to where it now does not work. Everything else seems to function correctly if you can get in a command. Does it sound like a membrane pad is needed ?
Kim
Groups: Joined: 12/1/2008(UTC) Posts: 0
Originally Posted by: kim bray Keypad was getting erratic at times. Progressively got worse to where it now does not work. Everything else seems to function correctly if you can get in a command. Does it sound like a membrane pad is needed ?
Kim Hi Kim. Yes, you will need to replace the keypad assy. Part number: AP3837496
