I just changed out the fuse in my dishwasher and it works fine but now it won't fill. If I put water in, it will cycle through and drain but will not add more water. Any suggestions? Thanks
did you turn off the water shut off valve for your dishwasher .usually under sink?
no I checked the faucet under the sink and it is in the on position (to the left)
Here is your parts breakdown Model KUDS01FKSS0Here is your tech sheet https://www.servicematters.com/d...0Sheet%20-%208524517.pdfIf you have a meter check across the water solenoid for voltage. If it is getting voltage then the valve is either shot or the valve's screen filter is clogged up. Another thing to check is the overfill switch/float. Usually left hand side front of the unit. Machine may think it is already full of water. Check/clean the connector at the control board. If you disconnected it make sure a pin has not backed out when you reconnected. |
THIS FORUM IS DEAD!!!!!!! |
