new owner
#1 Posted : Sunday, January 18, 2009 2:48:38 PM(UTC)
new owner
I just changed out the fuse in my dishwasher and it works fine but now it won't fill. If I put water in, it will cycle through and drain but will not add more water. Any suggestions? Thanks
misterfixall
#2 Posted : Sunday, January 18, 2009 6:31:22 PM(UTC)
misterfixall
did you turn off the water shut off valve for your dishwasher .usually under sink?
new owner
#3 Posted : Sunday, January 18, 2009 6:38:31 PM(UTC)
new owner
no I checked the faucet under the sink and it is in the on position (to the left)
#4 Posted : Monday, January 19, 2009 3:29:40 AM(UTC)
Here is your parts breakdown
Model KUDS01FKSS0
Here is your tech sheet
https://www.servicematters.com/d...0Sheet%20-%208524517.pdf
If you have a meter check across the water solenoid for voltage.
If it is getting voltage then the valve is either shot or the valve's screen filter is clogged up.
Another thing to check is the overfill switch/float. Usually left hand side front of the unit.
Machine may think it is already full of water.
Check/clean the connector at the control board. If you disconnected it make sure a pin has not backed out when you reconnected.
GE Dishwasher won't fill after grease (Dishwasher Repair)
by Guest 1/1/2022 3:18:27 PM(UTC)
Maytag dishwasher won't fill (Dishwasher Repair)
by dkirchner2@wi.rr.com 11/5/2014 5:40:40 AM(UTC)
Dishwasher won't fill or run (Dishwasher Repair)
by kevin.atkinson 11/28/2013 4:56:56 PM(UTC)
Dishwasher won't fill (Dishwasher Repair)
by mattgumaer 9/18/2013 7:02:29 PM(UTC)
Dishwasher Won't Fill (Dishwasher Repair)
by Rjkaster 1/12/2013 9:48:06 AM(UTC)
by SpedG 4/4/2012 8:23:34 AM(UTC)
Dishwasher won't fill, hasn't been used for months (Dishwasher Repair)
by talentetta 1/15/2012 10:49:50 AM(UTC)
GE Dishwasher won't fill (Dishwasher Repair)
by brotherleeroy 12/21/2011 9:53:36 AM(UTC)
Bosch dishwasher won't fill (Dishwasher Repair)
by sparky296 6/29/2011 1:17:33 PM(UTC)
Dishwasher Won't Fill -- Replaced Inlet Valve (Dishwasher Repair)
by wildwind 6/2/2011 12:23:53 PM(UTC)
by segriggs 3/21/2011 10:45:58 AM(UTC)
Dishwasher won't fill and pump is loud (Dishwasher Repair)
by angelo c 3/7/2011 5:41:40 PM(UTC)
Dishwasher won't fill (Dryer Repair)
by idgie 1/24/2011 5:44:35 AM(UTC)
Maytag Dishwasher won't fill w/ water (Dishwasher Repair)
by boehlcj 1/12/2011 4:31:14 PM(UTC)
Kenmore Dishwasher won't fill up to wash. (Dishwasher Repair)
by Samuel Murphy 10/28/2010 8:04:26 PM(UTC)
