wildwind
#1 Posted : Thursday, June 2, 2011 12:23:53 PM(UTC)
wildwind
Replaced the water inlet valve, still doesn't fill -- any ideas?
jamh
#2 Posted : Thursday, June 2, 2011 3:47:58 PM(UTC)
jamh
Chk voltage at water valve when unit should be filling with water, should be 120 volts. If no voltage replace control. If you have voltage then there is a problem with your water supply.
