This oven never worked right from day one. It was in the home when I purchased it new. My bad for not following up during warranty. Symptom, the oven does not hold a temp. The oven is either on, or off. It does not stop at any temp on the dial. If I try to adjust the temperature, the oven hits a point where it just turns off.
Any help apprreciated Dave Cappy.
Hi Dave The first thing I would check is the oven igniter. If it takes more then a minute to light up the burner, then the igniter is bad and has to be replaced. If there is nothing wrong with the oven igniter then the the problem is a bad thermostat. - The part number for the oven igniter AP2020569 - The part number for the oven thermostat AP3191697 The oven igniter The oven thermostat Good luck. Gene.
Gene, Thanks much for the quick response, and advice. Since the oven ignites in 20-30 seconds, I have ordered the thermostat. Having trouble finding a repair manual. this does seem as though it would be pretty straight forward to replace though. Thanks Again !!!
Keep me updated, please.
Gene, Part arrived Tuesday, replaced thermostat, oven now works beautifully. I tested temps 300, 350, 425, all 3 spot on. Thanks for the advice. Turkey beware :-)
