ocappe
#1 Posted : Friday, November 9, 2007 3:44:10 PM(UTC)
ocappe
This oven never worked right from day one. It was in the home when I purchased it new. My bad for not following up during warranty. Symptom, the oven does not hold a temp. The oven is either on, or off. It does not stop at any temp on the dial. If I try to adjust the temperature, the oven hits a point where it just turns off.
Any help apprreciated
Dave Cappy.
#2 Posted : Friday, November 9, 2007 7:08:34 PM(UTC)
Hi Dave
The first thing I would check is the oven igniter. If it takes more then a minute to light up the burner, then the igniter is bad and has to be replaced.
If there is nothing wrong with the oven igniter then the the problem is a bad thermostat.
- The part number for the oven igniter AP2020569
- The part number for the oven thermostat AP3191697
The oven igniter
UserPostedImage
The oven thermostat
UserPostedImage
Good luck.
ocappe
#3 Posted : Saturday, November 10, 2007 6:07:06 AM(UTC)
ocappe
Gene, Thanks much for the quick response, and advice. Since the oven ignites in 20-30 seconds, I have ordered the thermostat. Having trouble finding a repair manual. this does seem as though it would be pretty straight forward to replace though. Thanks Again !!!
#4 Posted : Saturday, November 10, 2007 9:34:48 AM(UTC)
Keep me updated, please.
ocappe
#5 Posted : Wednesday, November 14, 2007 4:31:56 AM(UTC)
ocappe
Gene, Part arrived Tuesday, replaced thermostat, oven now works beautifully. I tested temps 300, 350, 425, all 3 spot on. Thanks for the advice. Turkey beware :-)
Guest (5)
