dccory
#1 Posted : 18 years ago
dccory
Problem motor runs but inside freezer will not get cold.
Admin / APP Team
#2 Posted : 18 years ago
Admin / APP Team
Rank: Administration
Groups: Guests
Dccory,
Are you talking about the evaporator motor or the condenser motor?
Do you have a refrigerator thermometer? Can you tell me what the temperature is inside both the freezer and the fresh food section?
dccory
#3 Posted : 18 years ago
dccory
Originally Posted by: Admin / APP Team Go to Quoted Post
Dccory,
I't a chest type deep freezer was unpluged for a couple months and now will not get cold just the motor runs
Adam / APP Team
#4 Posted : 18 years ago
Adam / APP Team
Groups: Administrators
dccory,
If the compressor and fan motor are running however it doesn't get cold it could be the cold control or a problem in the sealed system.
If you have an ohmmeter you might check continuity on the cold control. It should have continuity when turned all the way up and no continuity with it turned all the way down.
For sealed system problems you will need to call a licensed technician to handle freon
mazzov
#5 Posted : 18 years ago
mazzov
dccory,
Were you able to figure out the problem? I am having the same problem with a Kenmore upright. I had the problem a few weeks ago and I noticed it had ice build-up on the bottom. I cleaned it out and it was working fine until this morning when I saw alot of water on the floor. Now it's blowing cold air again. I'm thinking it could be the thermostat. Please let me know your findings.
Thanks, Vince
mazzov@hotmail.com
dccory
#6 Posted : 18 years ago
dccory
Originally Posted by: mazzov Go to Quoted Post
dccory,
Thanks, Vince
mazzov@hotmail.com
Still have the problem decided to trash it .
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 9 months ago
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 10 months ago
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 10 months ago
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 10 months ago
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 10 months ago
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 10 months ago
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 10 months ago
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 11 months ago
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 11 months ago
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 11 months ago
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 11 months ago
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 11 months ago
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 12 months ago
