Originally Posted by: eggy  ...Last night it just 'died'... Can you describe it more detailed? Does anything work? How about lights inside and water dispenser? Gene.
Very well written article. This is very helpful to a non pro especially. There are some "Pros" out there who could benefit as well.. Again it was written in a very real easy to understand style, like someone would explain it to you in person and NOT sound like a engineer who writes manuals. Thank you
Kenmore dryer 110.96281100. Need to know how to test thermal cut off & high limit? Originally Posted by: Gene
Remove the wires from them and test both for continuity.
Nicely written. I am familiar with testing equipment, but I don't do it on a regular basis, therefore, it is helpful to have an article to fall back on.
Very kind of you to be so helpful to others. It is much appreciated.
Take care.
Thanks for the info, I hate to sound dumb, but I never ne any of this info. Now I do and it will really help a lot. Thaks...:o
In my Kenmore side-X-side refrigerator, I believe the solenoid for the crushed/whole cube ice selector is bad (I get no reaction pushing the door button when the door switch is depressed as well). I'm assuming this will be a continuity test? If there is an 'infinity' amount of resistance will it be bad? Doh? So, unplug the fridge, remove the wires and test the connectors...ta da!
Very helpful, still reading,learning, thanks.
I have a dual burner (Jenn Air JEC9536ADS)not working and want to check the control unit. Has a L1 and L2, however not a H1 and H2. There is a common (3) and an inner (2) and an outter (1). How would I properly test the control?
