circlek
#1 Posted : Thursday, October 20, 2011 1:58:43 PM(UTC)
circlek
My dryer suddenly will not turn on. I went to use it and there seems to be no power. I have checked the plug, and the breaker, this is not the problem. Is there a reset button? What else could be wrong?
#2 Posted : Friday, October 21, 2011 1:42:57 AM(UTC)
Here are your parts, includes a wiring diagram.
Replacement parts for CROSLEY CDE6500AZW DRYER- ELE | AppliancePartsPros.com
If he unit has a drum light and that also does not work then the thermal fuse (Item 5 in Section 5) comes to the top of the list.
Check it, it should be ohms.
If it is blown try to figure out what caused it to go.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal cut-off blows.
The hi-limit should have regulated the temperature so the fuse did not blow, that is why there is a new one with the thermal cut-off..
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it's contacts may not be opening (welded shut).
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Dryer will not turn on, need wiring/hookup info (Dryer Repair)
by rsflores9 6/14/2014 3:06:00 PM(UTC)
Samsung Dryer will not turn on (Dryer Repair)
by jijake1977 6/11/2014 7:48:39 PM(UTC)
roper dryer will not turn on (Dryer Repair)
by MrTry2fixit 4/26/2014 6:49:16 PM(UTC)
by Beefer 9/11/2013 8:03:09 PM(UTC)
Ge Harmony Dryer will not turn on (Dryer Repair)
by bavism 11/24/2012 11:06:45 AM(UTC)
Dryer will not turn on. (Dryer Repair)
by MWalton954 10/25/2012 6:43:55 AM(UTC)
Kenmore dryer will not turn on (Dryer Repair)
by 3dDetailer 8/27/2012 3:06:35 PM(UTC)
by dt611 12/17/2011 3:14:40 AM(UTC)
Dryer will not turn on. Please HELP! (Dryer Repair)
by greatdeals_007 10/20/2011 6:57:18 AM(UTC)
by Davy99 9/7/2011 3:26:54 PM(UTC)
by nannyb 7/9/2011 5:12:33 AM(UTC)
by andreabowen 1/1/2011 7:01:05 AM(UTC)
by lndn82 7/11/2010 8:30:10 AM(UTC)
Dryer will not turn on has power other test done (Dryer Repair)
by KCgallimore 7/6/2010 12:24:10 PM(UTC)
by jkessler 4/12/2010 3:53:30 PM(UTC)
