207 Pages«<137138139140141>»
blownfuse
#1381 Posted : Sunday, October 16, 2011 5:52:42 PM(UTC)
blownfuse
I have a Kitchen Aid KBRS36FKX00 that is about ten years old.
When the fridge was under warranty, the evaporator motor and
part of the wiring harness was changed as a known problem.
I am now having the same problem, the unit runs constantly and the
freezer works fine but the refrigerator section temperature has been rising.
I found on this forum a post by Gene where he had a link to a service manual for a side by side model. I was wondering if the procedures are the same for the bottom freezer units.
Read more: http://forum.appliancepartspros...post559422#ixzz1b03IXZFl
http://forum.appliancepartspros.com
#1382 Posted : Monday, October 17, 2011 1:35:52 PM(UTC)
The first thing I would do is remove the top grille and clean the condenser coils (#16 on the diagram). Make sure the fan next to the compressor is running.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KBRS36FKX00 BUILT-IN REFRIGERATOR | AppliancePartsPros.com
blownfuse
#1383 Posted : Monday, October 17, 2011 4:05:00 PM(UTC)
blownfuse
Thanks Gene, I will give that a try.
blownfuse
#1384 Posted : Tuesday, October 18, 2011 8:52:27 AM(UTC)
blownfuse
Gene,
I cleaned the coils. Now the refrigerator does not cool at all. I replaced the evaporator fan as it flunked the diagnostic test.
Now the compressor flunks the test as well as the defroster heater and bimetal.
I was wondering if you had a service manual for this model, I am using one for a side by side now.
#1385 Posted : Tuesday, October 18, 2011 11:30:21 AM(UTC)
Originally Posted by: blownfuse Go to Quoted Post
Gene,
This is very strange.
I did not find the service manual for this model but I did find the Tech sheet. It is attached to the reply.
File Attachment(s):
KBRS36FKX00 - Wiring Sheet - 2221120.pdf (760kb) downloaded 6 time(s).
blownfuse
#1386 Posted : Wednesday, October 19, 2011 5:52:10 AM(UTC)
blownfuse
Gene, things seem to working fine now, It took overnight for the temperatures to reach normal levels. Thanks for your help.
#1387 Posted : Wednesday, October 19, 2011 11:06:23 AM(UTC)
You are welcome. Normally it takes about 24 hours.
TYoffe
#1388 Posted : Thursday, October 20, 2011 2:59:04 PM(UTC)
TYoffe
we own a MAYTAG MTB1504ARS
I have similar symptoms. Freezer is fine. Fridge is warm. I have replaced the def. timer. Still no luck.
Service repair man wants to charge me 295 + tax for parts and labor for a defrost system. (we are in New York) Does this sound incredibly high?
Sean SL
#1389 Posted : Saturday, October 29, 2011 10:27:37 AM(UTC)
Sean SL
Hi, I have a Maytag MBF2258WEB0. I am getting a heavy frosty coating all across the evaporator every 6 days or so. The little duct flap in the refrigerator section seems to open and shut. I am assuming that there is a problem with the heater. I think that my unit uses a ADC rather than a timer motor. Is the problem usually with the heater, the Bimetal - Def, or the thermostat in the freezer? What should I do?
I checked the continuity of the heater and it measures OK. I am not sure where the Bimetal switch is. There is a round cylindical sensor clamped onto the cold lines going to the evaporator. I don't see any plug for it. It just seems to go up into the main harness.
#1390 Posted : Monday, October 31, 2011 12:28:57 PM(UTC)
Hi Sean,
There are no a separate ADC in your refrigerator. The defrost, as well as many other functions, controls by the control board (#5 on the diagram).
The bi-metal is usually located on top of the evaporator. It is shown as #14 on the diagram.
If the bi-metal is good, replace the control board.
- The bi-metal Part number: AP4310486
Guest (26)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
