Patricia Ratliff
#1 Posted : Sunday, January 11, 2009 9:55:50 AM(UTC)
Patricia Ratliff
my top loading washer will not drain or spin. I noticed a few months ago that it did not drain or spin on the delicate cycle only but now it is not draining and spinning on any of the cycles.
Please advise.
kayakcrzy
#2 Posted : Sunday, January 11, 2009 1:43:35 PM(UTC)
kayakcrzy
If it runs, and does not drain, you could very well have a broken coupler. Unplug the washer, and pull it away from the wall, and then lean it back, and rest it there. Then go underneath with your flashlight, and look behind the motor, you will see the coupler. One piece is mounted to the motor, with three nipples, and then you will see a black rubber piece mounted to it, and there will be another piece with three nipples mounted on the transmission. Make sure the nipples or the rubber is not broken. If all is well, remove the pump, and see if it is not clogged. get a 3/8s extention, and put it in the shaft of the pump, and turn it, and see if it turns. The pump is held on by a upper and lower clip. Tom ApplianceEducator.com
Patricia Ratliff
#3 Posted : Monday, January 12, 2009 4:34:31 AM(UTC)
Patricia Ratliff
Thank you immensely, I have printed your reply and will follow it to a "T".
You made my day.
kayakcrzy
#4 Posted : Monday, January 12, 2009 4:46:06 AM(UTC)
kayakcrzy
Thank You, I am glad to help. Tom ApplianceEducator.com
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
