When it was time for the rinse cycle, it made a clunk noise and woudn't fill with water. I tried to restart it and it still wouldn't fill with water. It does not give me an error code.
The fill control is controlled by the control unit, so that is suspect. A problem with the transmission is not something that should cause it not to fill, but I would take off the cabinet, remove and check the pump, motor and transmission and see if you can determine anything.
