I replaced the broil and bake elements on my stove and it still doesn't turn on.. the cooktop works fine but no bake or broil. Also there is no limit switch that's in the manual on this model so that can't be it. help??
THIS FORUM IS DEAD!!!!!!! |
If the limit switch is fine. The clock control board will be the problem. Tom
Ther looks like a limit switch on the back of the stove in the upper left corner by the oven sensor, could that be the problem?
i think this switch is at back centre towards bottom behind panel
It has 2 wires coming to it. Tom
