naudnice
#1 Posted : Friday, January 9, 2009 6:47:34 PM(UTC)
naudnice
I replaced the broil and bake elements on my stove and it still doesn't turn on.. the cooktop works fine but no bake or broil. Also there is no limit switch that's in the manual on this model so that can't be it. help??
#2 Posted : Saturday, January 10, 2009 1:24:26 AM(UTC)
Here is your parts breakdown
Model MER5755QAW
As long as you are sure thst the High Limit Thermostat #18 in the "Cabinet" section is missing, I would try to run the diagnostics in the tech sheet.
Check that you have 240 volts between P3-5/4 and P4-1/2 at the control board.
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16025644.pdf
http://www.servicematters.com/m...ibrary/docs/16025646.pdf
kayakcrzy
#3 Posted : Saturday, January 10, 2009 7:26:26 AM(UTC)
kayakcrzy
If the limit switch is fine. The clock control board will be the problem. Tom
naudnice
#4 Posted : Saturday, January 10, 2009 10:15:53 AM(UTC)
naudnice
Ther looks like a limit switch on the back of the stove in the upper left corner by the oven sensor, could that be the problem?
misterfixall
#5 Posted : Saturday, January 10, 2009 7:47:41 PM(UTC)
misterfixall
i think this switch is at back centre towards bottom behind panel
kayakcrzy
#6 Posted : Sunday, January 11, 2009 6:48:40 AM(UTC)
kayakcrzy
It has 2 wires coming to it. Tom
