I have a client whose kenmore DW pumps out while in wash cycle-what do you think?
A model number may help others help you.
Did the unit used to run OK? If not it could be the drain is not looped higher than where it enters the house plumbing or perhaps it has come loose and fallen.
If the unit has a separate drain pump you will have to find out if that pump is running when it should not be. The unit may also have a check valve or flapper valve that is not closing properly. |
THIS FORUM IS DEAD!!!!!!! |
The unit ran correctly one minute and next it didn't. All plumbing intact and check valve clear-no obstruction. No separate drain pump in system.No energized drain valve in system. Does this motor reverse in order to drain. Thanks denman for your ideas-Paul
Still need a model number. Kenmore does not make anything so it could be anyone's unit. Model Number Locator |
I'll be back w/model# etc. shortly thanks denman-paul
denman or others- kenmore m#-665.17425792 when dw in wash mode lead from relay shows 118v to N,wash lead from timer shows 45v to N,drain lead from timer shows 45v to N.It pumps out during both wash & drain modes. thx-paul
