paul martin
#1 Posted : Wednesday, October 12, 2011 7:06:08 PM(UTC)
paul martin
I have a client whose kenmore DW pumps out while in wash cycle-what do you think?
#2 Posted : Thursday, October 13, 2011 4:39:29 AM(UTC)
A model number may help others help you.
Did the unit used to run OK? If not it could be the drain is not looped higher than where it enters the house plumbing or perhaps it has come loose and fallen.
If the unit has a separate drain pump you will have to find out if that pump is running when it should not be.
The unit may also have a check valve or flapper valve that is not closing properly.
paul martin
#3 Posted : Thursday, October 13, 2011 6:14:26 AM(UTC)
paul martin
The unit ran correctly one minute and next it didn't.
All plumbing intact and check valve clear-no obstruction.
No separate drain pump in system.No energized drain valve in system.
Does this motor reverse in order to drain.
Thanks denman for your ideas-Paul
#4 Posted : Thursday, October 13, 2011 7:02:20 AM(UTC)
Still need a model number.
Kenmore does not make anything so it could be anyone's unit.
Model Number Locator
paul martin
#5 Posted : Thursday, October 13, 2011 7:44:08 AM(UTC)
paul martin
I'll be back w/model# etc. shortly
thanks denman-paul
paul martin
#6 Posted : Thursday, October 13, 2011 9:34:25 AM(UTC)
paul martin
denman or others-
kenmore m#-665.17425792
when dw in wash mode lead from relay shows 118v to N,wash lead from timer shows 45v to N,drain lead from timer shows 45v to N.It pumps out during both wash & drain modes.
thx-paul
#7 Posted : Thursday, October 13, 2011 1:14:50 PM(UTC)
Here are the parts
Replacement parts for KENMORE 66517425792 | AppliancePartsPros.com
The Sears parts site will have parts breakdowns.
Here is a manual. I am not sure if it is an exact match but looking at the pump it should be close.
http://appliancedigest.c...eshooting-service-manual
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
I would start with the soil separator it is a common problem.
File Attachment(s):
17425792.pdf (746kb) downloaded 3 time(s).
Guest (4)
