3 Pages<123
lkost
#21 Posted : Tuesday, October 11, 2011 2:48:51 PM(UTC)
lkost
If it's correct and the check valve is missing then you should have plenty of water inside the dishwasher while it's off for a while.
All I really want to know is "where is the check valve located and how do I find it and access it to replace:( :confused:
#22 Posted : Wednesday, October 12, 2011 12:11:16 PM(UTC)
The check valve is on the right side of the chopper, a black thing stuck in the housing
Read more: http://forum.appliancepartspros...asher.html#ixzz1abHJ3SMR
http://forum.appliancepartspros.com
lkost
#23 Posted : Wednesday, October 12, 2011 2:19:27 PM(UTC)
lkost
Gene , are you talking about the chopper cover or the slot that the right side of the chopper cover fits into. I have no black rubber anywhere so I can't tell where un it goes:(
#24 Posted : Wednesday, October 12, 2011 8:09:38 PM(UTC)
The following is the picture of the check valve.
UserPostedImage
lkost
#25 Posted : Thursday, October 13, 2011 7:04:55 AM(UTC)
lkost
I know what the check valve looks like. I just do not see anyplace where it goes:mad: I believe mine got eaten up so I need to know where to instal the replacement. There seems to be nothing to the right of ther chopper assy where it might go
#26 Posted : Thursday, October 13, 2011 10:01:50 AM(UTC)
Check the attached document.
File Attachment(s):
Check valve.doc (59kb) downloaded 3 time(s).
lkost
#27 Posted : Tuesday, December 20, 2011 1:57:03 PM(UTC)
lkost
:eek: Well, I now have replaced the chopper assy and check valve. Still does not work. Every two weeks I have to clean the chopper screen because it is totally plugged up on both sides. Is the only thing left that could cause this, a non working impeller.Is there any way to check to see if it is working? Wouldn't I need to acess from the bottom to replace?
#28 Posted : Wednesday, December 21, 2011 12:18:01 PM(UTC)
The same ongoing problem after the chopper has been replaced means the impeller is bad. Whirlpool does not sell it separate, so you have to order the whole new motor assembly. The instructions are attached to the reply.
- The circulation motor Part number: AP4434021
File Attachment(s):
How to replace pump & motor.pdf (1,122kb) downloaded 2 time(s).
3 Pages<123
