jtowntbo5@yahoo.com
#1 Posted : Thursday, January 8, 2009 7:24:04 AM(UTC)
jtowntbo5@yahoo.com
A GE washer I have is overfilling on large and extra large loads. I changed the pressure switch hose with a used one with no holes, and it still does it. The pressure switch shows good. Whenever it goes into agitation, the flood hose leaks water down to the base of the machine. The model number on the actual washer is not working, the closest one to it is WCSR4110TAWW. Any ideas would be greatly appreciated !!!
libertyappl
#2 Posted : Thursday, January 8, 2009 8:41:51 AM(UTC)
libertyappl
Here's your breakdown Model WCSR4110TAWW
Make sue there is no water in the pressure tube and it fits snug on both ends.
Nat
#3 Posted : Thursday, January 8, 2009 11:37:48 AM(UTC)
You used a used pressure tube.
Did you cut half an inch off the end which attaches to the pressure switch.
Also if the tubing is at all starting to get hard it will not seal properly.
On large loads more pressure is built up in the tubing if it leaks a little it will overfill.
jtowntbo5@yahoo.com
#4 Posted : Thursday, January 8, 2009 2:25:51 PM(UTC)
jtowntbo5@yahoo.com
I didn't cut any off of the hose, but the hose still has alot of flexibility. I've done it before for other models, whirlpool and say frigidaire, and they all worked fine thats why it had me puzzled. So, is that the only thing i could do.
#5 Posted : Thursday, January 8, 2009 2:48:01 PM(UTC)
No you could do a lot of things, including buying a new hose or trying to seal it with silicone sealant but that is what I would try first.
Washer overfilling (Washer Repair)
by 3DPiper 11/8/2016 10:23:12 AM(UTC)
GE Washer Overfilling (Washer Repair)
by Liriodendron 3/12/2015 11:48:35 AM(UTC)
washer overfilling (Washer Repair)
by Doug51 9/8/2013 9:44:36 PM(UTC)
GE Washer overfilling (Washer Repair)
by vman1 1/2/2013 10:39:21 AM(UTC)
by runningspike 2/20/2011 3:03:46 PM(UTC)
Washer overfilling and not automatically spinning (Washer Repair)
by stubby0011 8/11/2010 7:50:33 AM(UTC)
help with GE washer overfilling (Washer Repair)
by doomee 12/15/2009 12:46:50 PM(UTC)
by scotte 10/7/2009 7:00:39 PM(UTC)
dishwasher overfilling (Dishwasher Repair)
by Vulcan 12/14/2008 5:06:33 PM(UTC)
by xmasbaby63 8/16/2008 2:22:47 PM(UTC)
