stubby0011
#1 Posted : Wednesday, August 11, 2010 7:50:33 AM(UTC)
stubby0011
I have a WHRE5260E1WW top load washer. We have had problems with it overfilling and with it not spinning. \r\nTo fix the overfilling problem, I changed the pressure switch and tubing and it worked for about a week without overfiling, but I had to have it set on small and the amount of water it is filling up with is a lot more than small. Now it is overfilling even on small.
The washer also isn't going to the spin cycle on it's own. If I change the program to spin only and reset the water level then press start it will spin without a problem.
I am wondering what could wrong, the control board or something else..
#2 Posted : Wednesday, August 11, 2010 11:48:03 AM(UTC)
Would it stop filling if you unplug it?
Did you blow some air through the pressure tube to make sure it goes through?
Here are the breakdown diagrams and Replacement parts for General Electric WHRE5260E1WW Washer | AppliancePartsPros.com
stubby0011
#3 Posted : Wednesday, August 11, 2010 11:59:42 AM(UTC)
stubby0011
I haven't tried to see if it does fill with it unplugged. I can blow through the hose and the pressure switch does click.
#4 Posted : Wednesday, August 11, 2010 12:05:45 PM(UTC)
Did you use a new OEM pressure switch as the replacement?
What is the part number of the switch?
Check the wires connection to the pressure switch.
