garygordon
#1 Posted : Thursday, October 6, 2011 3:40:35 PM(UTC)
garygordon
how do you remove and replace the washer pump? I have the front cover off and can see the pump
sidfink43
#2 Posted : Saturday, October 8, 2011 5:08:08 PM(UTC)
sidfink43
The pump is attached to the motor. You will have to remove the motor and then take the pump off. Be sure and not how the belt goes so you can put it back the right way.
Good luck.
Washer pump replacement (Washer Repair)
by garygordon 10/6/2011 3:45:40 PM(UTC)
Bosch Nexxt 500 Washer Pump Replacement (Washer Repair)
by eblum 8/8/2011 8:32:13 AM(UTC)
LG Washer Pump Replacement Procedure (Washer Repair)
by dz63 3/15/2011 3:33:18 PM(UTC)
GE Washer Pump Replacement (Washer Repair)
by zakinsfbay 5/19/2010 9:05:37 AM(UTC)
Bosch Washer Pump Replacement (Washer Repair)
by ray ernst 10/18/2008 9:37:32 PM(UTC)
Dishwasher Pump Replacement/Cleanout (Dishwasher Repair)
by Ed De Meter 1/5/2008 9:07:40 AM(UTC)
