Replacement parts for WHIRLPOOL RED4440VQ1 29"ELECTRIC DRYER | AppliancePartsPros.comSee the attachment for the tech sheet.
[COLOR="DarkRed"].can the timer control keep the element from heating up?[/COLOR]
Yes it can the heating coil gets power through the AB and BC timer contacts.
In timed dry does the timer advance when the motor is running?
In timed dry the timer motor is connected directly to the 240 volts by timer contacts TF. So if it advances you know that you have 240 volts to the unit.
When the original timer would not advance did you try it in both auto and timed dry modes?
It's motor gets power through different circuit paths depending on the mode.
Beside the thermal cut-off in the heater circuit you also have the operating thermostat and the hi-limit thermostat.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
