snipersgt216
#1 Posted : Monday, January 5, 2009 3:58:43 PM(UTC)
snipersgt216
I chose to replace my freezer door gasket because it was pinched/folded over on the hinge side of the door and not sealing tight and sometimes popping open. I ordered the part and received it. I held the gasket up to the door (placing it over the old gasket). The new gasket is approx. 2 inches longer than the old one on the door. I am very hesitant to take the old off and place this new one on for fear it may do the same thing. Is this normal for the gasket to be that much longer? The height of the rectangle appears to be right on. What should I do?:confused:
#2 Posted : Tuesday, January 6, 2009 6:47:51 PM(UTC)
What is the part number for the gasket you've ordered? What is the color of it?
KBUDT4270A/02 SXS freezer door gasket (Refrigerator & Freezer Repair)
by metropical 3/19/2022 9:56:33 AM(UTC)
What Freezer Door Gasket Do I need (Refrigerator & Freezer Repair)
by mjrddell 7/17/2015 9:38:53 AM(UTC)
Whirpool freezer door gasket not sealing (Refrigerator & Freezer Repair)
by tannerthehammer 5/11/2013 11:20:13 AM(UTC)
Replacing Whrilpool freezer door gasket (Refrigerator & Freezer Repair)
by jerryrump 11/25/2012 7:36:43 AM(UTC)
Bottom freezer door gasket replacement (Refrigerator & Freezer Repair)
by PageinSC 7/18/2010 7:42:53 AM(UTC)
by grenoble 4/9/2010 7:23:57 AM(UTC)
Replacing freezer door gasket (Refrigerator & Freezer Repair)
by vynnette 2/14/2010 2:44:24 PM(UTC)
Freezer Door Gasket (Refrigerator & Freezer Repair)
by James E Rogers 1/11/2010 4:57:48 PM(UTC)
Amana refrig/freezer door gasket replace (Refrigerator & Freezer Repair)
by Lulalake 10/24/2009 9:59:16 AM(UTC)
Replacing food/freezer door gasket/seal (Refrigerator & Freezer Repair)
by mskalisiak 5/18/2009 6:51:34 AM(UTC)
Freezer door gasket to long (Refrigerator & Freezer Repair)
by snipersgt216 1/13/2009 2:30:20 PM(UTC)
by EJwins 11/11/2008 11:26:52 AM(UTC)
