vynnette
#1 Posted : Sunday, February 14, 2010 2:44:24 PM(UTC)
vynnette
Ordered the part #AP3038638 for the above mentioned freezer door,it would appear that the freezer door is sealed, there are no bolt/screws to pull the door apart. How do I get to replace the gasket which is what a local repair man told me was the problem, the gasket was damaged so the freezer was no longer airtight. This is the part for this freezer based on the model so how do I open the door to replace the gasket.
Regards,
V
#2 Posted : Monday, February 15, 2010 3:28:17 AM(UTC)
I could be wrong, but I think your gasket is a push-on item. There is a crease in the door frame that the gasket gets retained by pushing it in.
vynnette
#3 Posted : Thursday, February 18, 2010 5:16:54 PM(UTC)
vynnette
Thanks a lot, we will try that and will let you know how it turned out.
regards,
Vynnette
