Jim Lazar
#1 Posted : Tuesday, January 6, 2009 10:10:44 AM(UTC)
Jim Lazar
Hello:
I have an problem. The Y-Tube connector that leads from the Water Valve (shown as #83 Before Filter on the Water Filter Assy drawing) to the inlet line has broken. Specifically, the little white 3-way plastic connector that merges the 2 lines to 1 broke. How do I fix this? If I order the new valve (AP173484) which eliminates the Y-Tube, how do I connect this to the existing inlet line? Thanks for yr help.
Jim Lazar
Elisafaith13
#2 Posted : Tuesday, January 6, 2009 12:24:08 PM(UTC)
Elisafaith13
Originally Posted by: Jim Lazar Go to Quoted Post
Hello:
Jim Lazar
I have the same problem with my Amana Frige..did you get your part installed? HOW DID YOU DO IT?
Elisa
misterfixall
#3 Posted : Tuesday, January 6, 2009 5:58:13 PM(UTC)
misterfixall
when you get the new valve it will become obvious to you
Guest (4)
