Hello: I have an problem. The Y-Tube connector that leads from the Water Valve (shown as #83 Before Filter on the Water Filter Assy drawing) to the inlet line has broken. Specifically, the little white 3-way plastic connector that merges the 2 lines to 1 broke. How do I fix this? If I order the new valve ( AP173484) which eliminates the Y-Tube, how do I connect this to the existing inlet line? Thanks for yr help. Jim Lazar
Originally Posted by: Jim Lazar  Hello: I have an problem. The Y-Tube connector that leads from the Water Valve (shown as #83 Before Filter on the Water Filter Assy drawing) to the inlet line has broken. Specifically, the little white 3-way plastic connector that merges the 2 lines to 1 broke. How do I fix this? If I order the new valve ( AP173484) which eliminates the Y-Tube, how do I connect this to the existing inlet line? Thanks for yr help. Jim Lazar I have the same problem with my Amana Frige..did you get your part installed? HOW DID YOU DO IT? Thanks Elisa
when you get the new valve it will become obvious to you
