Hi, Mom owns a gorgeous kelvinator electric stove. The oven quit working and we think it might need a new top oven element. Do you know where I can find parts for this stove? The label on the inside warmer door says: Nash-Kelvinator Detroit, Michigan Model No. ER 489 Serial No. 340087 Max Watt 12580 Load Watt 12580 Electric Alternating Current Voltage 115/230-120/240
Any help is greatly appreciated! I would also eventually get the clock working and find out what kind of pan actually is supposed to be in that hole on the back stove top....but thats another project! :)
Thanks, Shelley
Shelley,
This model number does not come up due to age. Call the customer service at 877-477-7278 and ask for Adam. He will help you.
Gene. Thanks for responding Gene. I appreciate the help! I will call on Wed. Thanks again, Shelley
