cangrejo7
#1 Posted : Monday, January 5, 2009 10:04:13 PM(UTC)
cangrejo7
hi my refrijerator is driping water trough the air conductor, water is all over my food and then is turning in to ice i checked the temperature setting and try lower then the recomended for a week and still doing the same thing canyou please help me?:(
#2 Posted : Tuesday, January 6, 2009 7:39:49 PM(UTC)
Looks like the problem is a frozen drain in the freezer. Remove the rear panel in the freezer and locate the drain hole under the evaporator coil. You can use a hair dryer to defrost it and a turkey baster with hot water to make sure it is open.
Remove the cover on the back of the refrigerator and check the other end of the drain hose for a clog.
Kenmore cold spot icemaker (Refrigerator & Freezer Repair)
by jmarques6 8/25/2012 7:33:49 PM(UTC)
Kenmore Cold Spot Refrigerator (Refrigerator & Freezer Repair)
by sheaboyd 10/25/2010 2:49:58 PM(UTC)
kenmore cold spot 106 noot cooloing (Refrigerator & Freezer Repair)
by Diesel2010 7/17/2010 5:25:28 PM(UTC)
how old is the kenmore cold spot 106? (Refrigerator & Freezer Repair)
by bobbyd2 4/18/2009 8:33:26 PM(UTC)
Kenmore Cold Spot (Refrigerator & Freezer Repair)
by jmac357 1/29/2008 6:51:36 PM(UTC)
