Here is your parts breakdown
Model MEW5530DDBHere is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16022506.pdf http://www.servicematters.com/m...ibrary/docs/16022507.pdfYou will notice that 6, 10 and Bake keys all have track 10 on the ribbon cable in common (See Tech Sheet , Page 4 , Maytag Matrix).
Unplug the oven
Open up the control console
Unplug the keyboard ribbon cable from the control board.
If the ribbon cable is clear plastic check the tracks for hairline cracks, a magnifying glass helps here.
If the cable is the type where they just remove the insulation for an edge connector. The cable end can be cleaned with a pencil eraser. Do not use an ink eraser, it is too abrasive.
Would not hurt to also clean the connector on the control board. Use electronics cleaner or isopropyl alcohol and a tooth brush. Be gentle and also make sure all the solvent has evaporated before reconnecting.
With a little luck all it needs is a cleaning.
If the above does not work.
The tech sheet does give the procedure for checking the keys with a multimeter. If you have a meter I would do this before reconnecting the cable above.
You will need a meter. If you do not have one I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
