raderrustler
#1 Posted : Sunday, January 4, 2009 8:33:49 PM(UTC)
raderrustler
I have a Maytag builtin 30" oven, The touchpad will not beep when I depress the Bake button, The 6 numeral, or the 9 numeral the oven light button does not beep either. The Broil feature works as well as the keep warm warm feature which tells me both elements (broil top,and Bake lower are working. All the other buttons beep when depressed. I am wondering if this could be a Control panel issue part ap3495120, or could the Clock, part ap3127552 be causing the control panel to not beep. Both parts are over a hundred dollars and where I live it is a 50 dollar surcharge on top of a 90 dollar inspection fee...very pricey. I do almost allAny help would be appreciated as I am not a rich person. Is there a way to check the control panel functions? or is blind guess and keep replacing parts the accepted method. Thanks in advance.
#2 Posted : Monday, January 5, 2009 1:55:55 AM(UTC)
Here is your parts breakdown
Model MEW5530DDB
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16022506.pdf
http://www.servicematters.com/m...ibrary/docs/16022507.pdf
You will notice that 6, 10 and Bake keys all have track 10 on the ribbon cable in common (See Tech Sheet , Page 4 , Maytag Matrix).
Unplug the oven
Open up the control console
Unplug the keyboard ribbon cable from the control board.
If the ribbon cable is clear plastic check the tracks for hairline cracks, a magnifying glass helps here.
If the cable is the type where they just remove the insulation for an edge connector. The cable end can be cleaned with a pencil eraser. Do not use an ink eraser, it is too abrasive.
Would not hurt to also clean the connector on the control board. Use electronics cleaner or isopropyl alcohol and a tooth brush. Be gentle and also make sure all the solvent has evaporated before reconnecting.
With a little luck all it needs is a cleaning.
If the above does not work.
The tech sheet does give the procedure for checking the keys with a multimeter. If you have a meter I would do this before reconnecting the cable above.
You will need a meter. If you do not have one I would suggest you purchase one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
raderrustler
#3 Posted : Monday, January 5, 2009 7:05:47 PM(UTC)
raderrustler
Thanks for the info on the ribbon cables, I have a couple of good fluke meters and a modelers magnifying glass. I will check out what I can and see what develops and post back with results....Thanks again, Great Site:)
