MeanGene
#1 Posted : Thursday, September 22, 2011 4:39:41 PM(UTC)
MeanGene
The washer will not spin, it just fills up with water and sits there. Replaced the coupler and pump because they needed it. The motor will just hum until the internal breaker pops. The motor stop humming when you open the lid. The motor does turn. Took it out and benched tested the wires with an ohm meter and everything checked out OK. Maybe the motor Centrifugal switch?
MeanGene
#2 Posted : Saturday, September 24, 2011 4:04:31 PM(UTC)
MeanGene
I have checked the motor switch and it seems to be OK, still want to figure out what is going on with this.
#3 Posted : Sunday, September 25, 2011 1:24:03 AM(UTC)
Check for lateral play in the motor shaft, if so, replace the motor.AP2907254
MeanGene
#4 Posted : Tuesday, September 27, 2011 3:45:31 PM(UTC)
MeanGene
I checked the lateral play and there is some. When you move it back and forth there is a slight clack. It measured around .024 in total movement. Would that cause the problem, motors aren't cheap.
#5 Posted : Wednesday, September 28, 2011 12:52:14 AM(UTC)
You have a bad motor, bearing play causes the rotor to jam against the stator housing.
Guest (4)
Whirlpool Washer will not spin and ultimately drain (Washer Repair)
by cvaughn101683 2/11/2014 3:30:01 PM(UTC)
Whirlpool washer will not spin without me manually turning the drum (Washer Repair)
by anc6802 12/21/2011 3:28:19 PM(UTC)
whirlpool washer will not spin (Washer Repair)
by mustangjones1 2/17/2011 4:32:58 PM(UTC)
Whirlpool washer will not spin (Washer Repair)
by ski1of5 9/1/2010 4:23:29 PM(UTC)
Whirlpool Washer will not spin clothes completely (Washer Repair)
by alinosa 5/28/2010 5:16:29 PM(UTC)
